TwinTurbo.NET: Nissan 300ZX forum - Try using anti-seize and a 12.9 nut
Subject Try using anti-seize and a 12.9 nut
Posted by zorpman1 on May 23, 2010 at 6:40 AM
  This message has been viewed 85 times.
In Reply To Installing wheel studs. posted by 4-EZTT on May 22, 2010 at 07:19 PM
Message Use anti-seize compound on the unthreaded part of the stud shaft and use a high quality 12.9 nut. Also but anti-seize on both sides of the undernut washer.
You could also put the studs (and nuts) in the freezer for several hours and work quick on the install. Remember that you are talking an interference fit of less than .002 inch.
